0 Members and 1 Guest are viewing this topic. Read 3084 times.
Maybe you could get those desk separaters used in offices and surround an area for listening. You can get them with padding and even add some of your own. That would help alot and be pretty cheap if you get them used. Won't be much for the looks department but could make a huge difference on the sound you're hearing. That room has to be way to reflective. If you're going to furnish it I'd add plenty of thick rugs or carpet. You want to add all the damping in there you can get away with.
Quote from: warnerwh on 10 Apr 2007, 05:52 amMaybe you could get those desk separaters used in offices and surround an area for listening. You can get them with padding and even add some of your own. That would help alot and be pretty cheap if you get them used. Won't be much for the looks department but could make a huge difference on the sound you're hearing. That room has to be way to reflective. If you're going to furnish it I'd add plenty of thick rugs or carpet. You want to add all the damping in there you can get away with. That would be my suggestion as well.Karsten
DIY oak(matching the floor) QRD diffusors, bass trapping columns (with may be bronze bust or two on top), Yucca or bamboos, Oriental rugs, etc. I see great possibilities in this room.
Insert QuoteWelcome to our world. Our as in the Europeans, the NYC dwellers, etc. Of course, not all of us have super live rooms, but many/most of us do. With all due respect to Frank VA, most american hi-fi retailers has this attitude, which frankly does nothing to help a very significant portion of the population that can't opt for something else. Audio has to be made to coexist in what you have to work with. It isn't always practical/plausible to do something else.
I'm going to go out on a limb and say that asides from getting a few rugs to cover the floor (not just the area between your listening seat and the speakers) plus some reasonable amount of furniture, I bet your system is going to sound pretty darn good in this room without doing much to it. The rugs and furniture will help reduce the brightness and any hard slap echo, and the natural decay that you'll get in a large room like this is not a bad thing IMHO...
