Omega Super 3i's and REL TZERO subwoofer
0 Members and 1 Guest are viewing this topic. Read 923 times.
N0AH
« on: 17 May 2024, 08:48 pm »
I just started putting together a new desk top rig using a Schiit Gjallarhorn powering some Super 3i's. Would a REL TZERO be a good match to give the speakers a good bass foundation for nearfield listening?
Schiit Bifrost 2/64 -> Schiit Jotunheim 2 -> Schiit Lokius tone control -> Schiit Gjallarhorn -> Omega Super 3i -> REL TZERO
opnly bafld
Re: Omega Super 3i's and REL TZERO subwoofer
« Reply #1 on: 17 May 2024, 11:10 pm »
Sure
Small room?
A T/5 would probably be better.
N0AH
« Reply #2 on: 18 May 2024, 01:05 am »
Small room subwoofer sitting under the desk I am sitting at. Only for near field music listening.
opnly bafld
« Reply #3 on: 18 May 2024, 09:22 pm »
The Tzero will add something, but it is more what I consider a bass module or helper woofer.
The T/5x is only a little larger, but $200 more expensive and perhaps not in the budget.
Looking new or used?
N0AH
« Reply #4 on: 9 Aug 2024, 02:50 am »
I ended up with a REL t5x blended much better with Super 3i's
opnly bafld
« Reply #5 on: 9 Aug 2024, 11:59 am »
 8)
