Well, the trouble continues. I have done a factory reset numerous times. A few seconds after the reset the voice says WiFi restored. I can't get it to simply use the ethernet connection. The device WANTS to use WiFi. This has become very frustrating.
How do I override its desire to use WiFi and force it to use ethernet?
In the software device setup, when I select use other network only WiFi access points are displayed, no ethernet options.
In the Browse screen: Select a source on device... This always reverts to WiFi. There is no ethernet option. If I select Co-Axial (I know this is not ethernet) it interrupts the stream.
