Mike, how do you veneer around edges and corners like that? Not that I plan on trying it, but it would be nice to know how you do it. Beautiful work.
Alan,
I use a veneer with a 22.2mil bubble free backer. This is thicker than the normal 10mil backer which makes it easier to roll around the edge. I also use veneer softener to make the veneer as pliable as possible.
The smaller the radius of the roundover, the harder it is to roll smoothly without cracking. I find a 3/4" radius easiest to work with.
Then I use Heat Lock glue and an iron to apply the veneer. PeterJ has a good YouTube video on how to do this.
Mike
